Calculator Designs Message #1 Posted by David Yerka on 13 Apr 2004, 6:06 p.m.
Personally I like the "4-line" stack display concept--so long as the lines are true alphanumeric and able to display at least as much info as the 41's alpha register. 4 lines displaying labeled results should be enough for most programs.
Has anyone considered a "pop-up" concept for a graphing display. Sort of like the Palm Tungsten PDAs. The display slides into the body with only enough of the top showing for 4+ lines. For graph/graphics display it pulls out fully.
Granted this makes for a less durable body but allows for a more compact package.
Of course, with generalized I/O (calculator as a master USB controller) it shouldn't be too difficult to create a lcd display, battery powered, to serve as a graphic display. After all the 41 w/IL had a CRT controller.
