Anyone use an HP-IL modem with a 41? Message #1 Posted by Jim Creybohm on 5 Apr 2004, 9:47 a.m.
I was reading about the HP-IL the other day and came across the modem. I am curious to hear if anyone has experience using the modem and a 41. I can see how the 71/75 might be used as they run BASIC, in which you can open and access serial ports.
The 41 however, has no way to push data out a serial port. So, does the modem have a command superset that the 41 can access and use? What type of program would be running on the server side? A DOS type BBS?
The passing of any experiences with this (and applications) would be of interest.
TIA
12345
