Re: hp 33s programming Message #5 Posted by Norris on 4 Apr 2004, 6:06 p.m., in response to message #1 by marcus channell
You can't use duplicate labels on the 33S.
If you have a lot of small programs, you can save labels by using GTO . [line number] R/S to launch them, instead of XEQ [label].
Say you have 10 different programs. Start the first one at line A 0000, the second at line A 0100, the third at line A 0200, etc. Don't label the beginning of the program. Fill in any extra lines between programs with RTN statements.
Then to start the second program, you would enter:
GTO . A 0100, followed by R/S
The GTO will move the program pointer to line A 0100, and the R/S will start the program that begins there. It's not as easy as typing XEQ A, but it works
