Re: hp12c problem - the [f] [number_key] sequence Message #5 Posted by Vieira, Luiz C. (Brazil) on 18 Mar 2004, 11:51 p.m., in response to message #1 by Kipp Butler
Hello, Kipp;
as the others helped you with the other subjects, please take the sequences:
[f] and any [number_key] or[f][.] as the standard sequences to customize number representation. ([number_key] means any key from [0] to [9])
As you can see, there's no golden inscription in the keyboard under each number key and the [.] (dot key), neither any suggestion in the keyboard that these [f][number_key] or [f][.] define the number representation.
With [f][2] you restore default "financial" representation: two fixed decimal places. Any other [f][number_key] sets another number of decimal places (digits). The [f][.] sequence sets "scientific" representation, with a ten-digit mantissa and a two-digit exponent of ten. About mantissa digits: seven are directly visible, and if you want to see all ten digits you press [f]CLEAR[PREFIX] and hold the [ENTER] key down for as long as you want to.
My 2¢.
Luiz (Brazil)
Edited: 18 Mar 2004, 11:52 p.m.
