Re: Buttons don't work on 32SII Message #4 Posted by Arnaud Amiel on 24 Feb 2004, 5:19 p.m., in response to message #3 by Ron Z
Right under where you pressed, there is a piece of foam that maintain the keyboard connectors in place. As it gets older, the foam loose its spring and the connection fails to happen.
Openning the 32SII involves a drill in the right places. Once open you can put a tiny piece of whatever to make the foam thicker and with lots of luck when you manage to put the calc back together, it will work again.
My advice, get a 33 it seems very good and not so ugly.
Arnaud
