Re: how to best take pix of my hp's! Message #8 Posted by Larry Corrado, USA (WI) on 26 Jan 2004, 7:28 a.m., in response to message #1 by linter
I've done a little digital photography and have a few simple things I've found successful.
* Get your outside light from a window. I have a bay window that faces south which works fairly well. (I was snapping pictures the other day at temperature 2 deg F.)
* Add an extra light source from a lamp of some sort. I try to have light from several directions to minimize shadows.
* To keep reflections down, experiment with different camera angles. Also, try propping up the calculator (so that it doesn't sit flat of the background surface.)
* Try different flash settings (including off.)
* Try different camera speeds.
* I have no camera mount either, but I try to lean the camera (or myself) on something rigid as I take the picture. (People walking by outside sometimes wonder why we have a foot stool in the bay window.) Holding the camera close to your body is helpful, as is holding your breath when you press the button.
* Digital photos are cheap: try different things, and throw away the bad shots.
Hope this helps. Good Luck!
Larry
PS, I've found these tips also work with TIs and Casios :-^
