Re: HP-IL module trouble Message #2 Posted by Raymond Del Tondo on 16 Jan 2004, 12:40 p.m., in response to message #1 by Stephan
have you tried testing the IL interface by plugging both connectors together, building an empty loop?
At least the loop should be ok then.
If not, either the IL cable or the electronics of the module are bad. In most cases the cable is the reason.
Raymond
