Re: Defect HP-42S Message #6 Posted by Victor Koechli on 8 Jan 2004, 5:20 p.m., in response to message #2 by Raymond Del Tondo
Thanks everyone for you help, I've solved the problem. It required resoldering the RAM chip, and now everything's fine. The two articles about opening the Pioneers by Paul Brogger were also extremely helpful.
What I've done differently is the removal of the lower heat stakes. I've pulled off the metal overlay and drilled out the heat stakes after trying to pry the case halves apart with my fingers. Obviously my fingers aren't as strong as Paul's ;-) Removal of the overlay is actually quite easy, provided you're patient and careful enough. Oh, and I did everything wrong: Used a 500W power drill, no ESD protection, no temperature controlled soldering iron - you get the picture. These little bastards are quite tough!
Anyway, I've taken a few hi res pictures, I could mail them or put them up on my website in case anyone is interested. Or if Dave wants them...
Thanks again, Victor
