Hi. This is the qmail-send program at mta1-1.us4.outblaze.com.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<giuseppe.marullo:iname.com@iname.com>:
Error 01373: User's Disk Quota Exceeded.
Sorry, your intended recipient has too much mail stored
in his mailbox.
Your message totalled 1209 Kbytes.
However a small (< 1Kb) message will be delivered should
you wish to inform your recipient you tried to email.
--- Below this line is a copy of the message.
Return-Path: <xeq41@tele2.fr>
X-OB-Received: from unknown (205.158.62.26)
by 205-158-62-61.outblaze.com; 2 Jan 2004 13:51:57 -0000
Received: from fep01-svc.swip.net (fep01.swip.net [130.244.199.129])
by spf4.us4.outblaze.com (Postfix) with ESMTP id 28BB31BAE7A
for <giuseppe.marullo@iname.com>; Fri, 2 Jan 2004 13:51:42 +0000 (GMT)
Received: from 1628mo ([80.170.227.185]) by fep01-svc.swip.net with SMTP
id <20040102134931.XQTD3280.fep01-svc.swip.net@1628mo>
for <giuseppe.marullo@iname.com>; Fri, 2 Jan 2004 14:49:31 +0100
Message-ID: <000801c3d137$1beb0760$b732fea9@1628mo>
From: =?iso-8859-1?Q?Emmanuel_Comp=E8s?= <xeq41@tele2.fr>
To: "Giuseppe Marullo" <giuseppe.marullo@iname.com>
References: <20040102013602.99775.qmail@iname.com>
Subject: Re: Software for ISA card
Date: Fri, 2 Jan 2004 14:48:25 +0100
MIME-Version: 1.0
Content-Type: multipart/mixed;
boundary="----=_NextPart_000_0005_01C3D13F.7A2696C0"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 6.00.2800.1106
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
This is a multi-part message in MIME format.
------=_NextPart_000_0005_01C3D13F.7A2696C0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Dear Giuseppe,
Try the attachment. ;o)
First at all you have to 'deturbo' your speed (please enter your Bios)
because
ISA bus on 286/386/486 is 8MHz, on Pentium 10MHz (!!!)
Declare in config.sys : device=c:/.../hpil.sys (... is the directory where
hpil.sys is)
I don't think your card is out of order. ;o) again.
Best wishes for 2004. Yours.
Emmanuel
