Re: Help needed for displaying strings with INFORM Message #2 Posted by Veli-Pekka Nousiainen on 28 Dec 2003, 6:49 a.m., in response to message #1 by Karl-Ludwig Butte
Posted by Karl-Ludwig Butte on 28 Dec 2003, 4:45 a.m.
There is a problem with the following code fragment: << "Titel" { { "Item 1 " "" 0. } { "Item 2 " "" 0. } { "Item 3 " "" 0. } } { } DUP IVal "SVal1" "SVal2" 3. \->LIST INFORM \>>
Althought the code doesn't produce an error message, the strings SVal1 and SVal2 are displayed in quotes as shown here: Item 2 "SValue1" Item 3 "SValue2"
Does somebody know how to avoid the quotes ? Any hint will be very much appriciated - thank you very much in advance.
Well - don't put them on quotas! What are you trying to do here? You may use STR-> to evaluate "SValn" or you may use the names in single quotas 'SValn'. [VPN]
