No, but here's my entry Message #4 Posted by Randy Sloyer on 20 Dec 2003, 8:38 p.m., in response to message #1 by Mike
When removing bezels, successful is a relative term...
The only way I have ever been able to get a bezel off any Voyager or Pioneer is to use a hot knife from the back - cutting away at the plastic and peeling it off the metal in small chunks. Takes a while and the ABS stinks to high heaven but you end up with a clean bezel. You might be able to use dental floss like a cheese cutter wire and UN-DU to lift from the front. At each key column or row, you'll have to pull the floss over each key to prevent creasing. I use Glide floss as it is flat and polypropylene. It is much stronger than the regular stuff. I have been able to remove the top silver bezels this way without damage. Takes awhile but it can be done.
While not a 15C, here's my ugly Voyager entry. Yes, it really is a 10C. It is obvious it was used as an RPN 4 banger - look at the major wear on the right side and the thick dirt level on the left. The actuation pin on the + key was worn to a nub. All keys on the right side had been pounded on for so long that the normally square edges of the keys had been completely rounded over, more like a Pioneer key. I replaced all the keys on the right side with keys from a Singapore 12C after removing all the blue shift functions.
