Re: HP-15C strange key click sound Message #2 Posted by Victor Koechli on 13 Dec 2003, 12:46 a.m., in response to message #1 by Miki Mihajlovic
I've never heard such a sound, but a possibility is that some of the heat stakes that fix the keyboard PCB to the calculator front have become loose, and what you're hearing could be the PCB moving.
I'd open the calc and check. It's quite easy to fix, actually, the plastics that came off would be floating around inside the case...
Good Luck! Victor
