HP Forum Archive 14
How many calcs do you have. (curious)
Message #1 Posted by Marc on 2 Dec 2003, 11:48 a.m.
I do have 3 HP48GX, 1 48G+, 2 32SII, and a 17 Bii.
Re: How many calcs do you have. (curious)
Message #2 Posted by Valentin Albillo on 2 Dec 2003, 11:57 a.m.,
in response to message #1 by Marc
Hi, Marc:
    Hewlett-Packard ...........  23
    SHARP .....................  45
    Tandy Radio Shack .........   4
    Casio .....................   1
    Assorted ..................  10
    Slide rules ...............   1
                Grand Total ...  84
Best regards from V.
Message #3 Posted by Nick on 2 Dec 2003, 12:34 p.m.,
in response to message #2 by Valentin Albillo
Hello Valentin: I'm curious about the Sharp calculators you have. How do they compare to HP calculators? What models do you consider the better ones? Thanks, Nick
Message #4 Posted by Gianmaria on 3 Dec 2003, 1:42 a.m.,
in response to message #3 by Nick
Some of my HP calculators are pictured here: http://www.hpcalculators.net but many others aren't, I'm still too busy (or too lazy :-) to add more pictures. However the best I have is the HP-9100A, I like sometime to switch it on and play "Moon rocket lander", the software had been loaded from magnetic card more than one year ago and is forever present in the magnetic core memory (a true continuous memory!)
SHARP vs. HP comparisons [LONG]
Message #5 Posted by Valentin Albillo on 3 Dec 2003, 6:19 a.m.,
Hi, Nick:
Nick posted:
"I'm curious about the Sharp calculators you have. How do they compare to HP calculators?"
All the models I have but one are what they used to call "pocket computers" as opposed to "pocket calculators". As such, they usually are much faster than HP's, have much larger RAM, are programmable in an advanced version of BASIC, have full I/O capabilities (even the smallest models), and boast larger, dot-matrix, alphanumeric and graphics displays, sometimes 2-line or 4-line, and support keyboard redefinition and assignment of program entry points and arbitrary definitions or sequences of characters to keys.
All can be programmed in machine language by using PEEK, POKE and CALL, all have 12-digit accuracy, all can recall the executed command line for re-executing it or edition at the touch of a key, all can insert the last result in the middle of a new computation, or continue an already executed expression.
IMHO, the main operational difference between "pocket computers" and "pocket calculators" at this level of price and size, is, briefly, that "pocket calculators" have very extensive preprogrammed capabilities but essentially poor programming capabilities (small RAM, slow, low-level language) while "pocket computers" have larger RAM, faster speed and high-level language, but less preprogrammed features, *unless* they are specialized models, which effectively provide the best of both worlds.
These specialized SHARP models, akin to the Voyager series, have been fine-tuned for such fields as business & finance (a la HP-12C), statistics, matrix operations (a la HP-15C), CASL and statistics, and computer science (a la HP-16C), among other applications and fields. They do have the same advanced BASIC with the same base capabilities, but extended with their specialized functions set (say, IRR computation in the finance model), fully integrated with the BASIC language so you can use them in your own programs.
Some models also feature a separate "calculator mode", where you can use the machine as a typical algebraic calculator, albeit with a larger function set (hyperbolic, statistics, matrix operations).
Considering all the facts, it's difficult to see why HP models are usually considered 'the very best'. Take, for instance, the comparison between two financial models, the HP-12C and the SHARP PC-1421 (aka EL-5510 in the US).
  • Both are more or less the same size, with the 1421 being slightly longer (6.7" vs. 5.1") but less wide (2.8" vs. 3.1" ) and also 50% thinner (0.4" vs. 0.6"), both weight more or less the same (5 oz. vs. 4 oz.), but the 1421 has a shiny, full metallic body with a slight golden tint.
  • The 1421 has a fully alphanumeric, dot-matrix, 16-char LCD display, vs. the HP-12C's numeric-only, 12-char, segmented LCD.
  • The HP-12C's keyboard is better, but that doesn't mean the 1421's is bad, quite on the contrary it's perfectly usable and long-term reliable as well.
  • The SHARP-1421 is programmable in an advanced version of BASIC, including long variable names, two-dimensional arrays, string arrays, I/O commands including printing and serial I/O, multi-statement lines, easy program editing with insertion, deletion, and editing of whole lines, and can use up to 4 Kb for programs and data.
    Further, all BASIC commands and statements are internally tokenized, so that "INPUT", for instance, takes only 1 byte (not 5), which helps save RAM and improves speed. All financial statements and functions can be used in BASIC programs. Besides, it can be programmed in machine language if need be, or desired, or just for fun, without any add-ins. You can enter several programs at once and assing their entry points to specific shifted keys on the keyboard for immediate execution.
    On the other hand, the HP-12C is programmable in RPN keystroke language, no insertion or deletion of lines, no advanced programming features at all, not even subroutines (!). Programs can be 99 bytes long, and that's all. Machine language programming is out of the question, and not only can't you assign programs to keys, but it doesn't even have labels to mark their entry points.
  • The SHARP-1421 is fully alphanumeric, and has a full QWERTY keyboard, including lowercase characters. The HP-12C has no alphanumerics whatsoever, so that even program steps have to be displayed as numeric keycodes, and neither inputs nor results can be labeled at all.
  • The SHARP-1421 has complete I/O capabilities, can be connected to a printer, to a mini-tape recorder, and to arbitrary serial I/O devices, with full support from dedicated BASIC commands. The HP-12C has no I/O whatsoever, not even printing, which some business users could probably have a use for.
  • The SHARP-1421 is *much* faster than the HP-12C, more than 20 times faster. Like the HP-12C it also has continuous memory, and like the HP-12C, it uses standard batteries (CR-2032) which last very long.
Considering all these facts, it's easy to see that the SHARP-1421 is, by far, the most powerful and arguably better handheld for business applications, capable of running very long and complex financial programs dealing with large amounts of data at great speeds, while labeling all inputs and outputs and storing them on tape, sending them to a printer, or to a serial device.
Similar comparisons could be made between other HP models and their SHARP counterparts.
"¿What models do you consider the better one?"
It depends on whether you're considering them just for collecting purposes, only to use them, or both. Obviously, the very first models are much less powerful than the later ones, but they *were* the very best at their time, so the comparison would be unfair. Anyway, here's a commented selection of the ones I consider best:
  • Specialized for business applications: the SHARP PC-1421 (EL-5510) is an incredible machine, the very best bar none.
  • Specialized for statistics: the SHARP PC-1425 is to statistics what the 1421 is to business, another incredible machine with powerful statistic functions and data gathering and analysis features integrated with its BASIC language and up to 32 Kb RAM.
  • Specialized for number-crunching: the SHARP PC-1475, it has a large 2-line x 24-char alphanumeric display, very fast built-in matrix commands and statements including inverse, determinant and system solving plus a convenient matrix editor to enter and edit them, up to 128 Kb RAM for BASIC programs and data, a separate calculator mode & keyboard, a very comprehensive array of math functions, plus it features double precision for variables and results, up to 20 decimal digits.
  • General purpose: the SHARP PC-1262 is incredibly small (HP-15C size), metallic, has the same BASIC and I/O capabilities, 10 Kb RAM, 40 Kb ROM, 2-line x 24 char alphanumeric display, full QWERTY keyboard, comprehensive help menus, very fast.
  • General purpose, large screen: the SHARP PC-1350 and PC-1360 do have a large 4-line x 24-char, fully alphanumeric and graphic display, including specific graphic BASIC commands and statements. They admit up to 20 Kb and 64 Kb RAM, respectively, by using small RAM cards in various sizes, which keep the programs intact even when removed from the machine. This allows you to have a series of long, complex programs and data stored on cards and swap them in and out of the machine in mere seconds. And to top it all, you can interface them to RS-232 devices large and small.
    For me, it is the most pleasurable machine to write programs in without using paper, because of its large display, which can show many statements at a time, plus full QWERTY keyboard. You can do amazing graphics and menus with it easily.
There are many, many other models worth mentioning, such as the ultra-capable, 2-processor, 80 Kb RAM PC-1600, the incredibly built-in library and ultra-fast speed of the 544 Kb RAM (!), 4x40 display PC-E500, the specific models for machine language programming such as the PC-E220, the superbly beautiful earlier models (like the PC-1211 pocket computer and the EL-5100 and EL-5101 (left) advanced calculators, which surely are the most beautiful advanced calculators in the world), etc, but this post would get even more unreasonably long, so let's stop here :-)
Edited: 3 Dec 2003, 9:32 a.m.
Message #6 Posted by Scuba Diver on 2 Dec 2003, 12:08 p.m.,
I have:
Sharp EL-5050 Sharp EL-9000
and as far as HPs go:
2 10B (1 is Indonesian and it pops when certain keys are pressed), 3 12C (one of which is used on a daily basis at work), 1 14B, 1 15C, 2 17BII, 3 19BII, 2 20S (NIB), 2 28S, 1 48GX, 1 48SX, 1 71B
for a grand total of: 21 (with 19 of them HP)
My earliest calculator is from 1982 (one of the 12Cs), so I'm definately a collector of the newer HPs. These are the ones I remember people using in university.
B.
Message #7 Posted by james summers (UK) on 2 Dec 2003, 12:26 p.m.,
in response to message #6 by Scuba Diver
5 HPs (12C, 34C, 41CX and 2 x 41CV)
2 TIs (58, 30)
3 Casios
and 4 slide rules (3 normal and 1 circular flight computer).
Message #8 Posted by Nelson M. Sicuro (Brazil) on 2 Dec 2003, 12:45 p.m.,
My calculators are: (NW = non working)
HP: 23 (6S, 10B, 10BII, 11C, 3x12C [1 NW], 15C, 17B [NW], 17BII engl., 17BII intl, 20S, 32E, 32S, 37E [NW], 38C [NW], 41CV without S/N, 41CV [NW], 42S, 48G, 2x95LX, 200LX)
TI: 10 (SR51A [NW], TI-30, 2xTI-55, TI-66, TI-2550, TI-Programmer, TI-MBA, TI-Money Manager, TI-5045SV)
Sharp: 2 (EL1611P, PC-1260 + CE125P)
Commodore: 2 (SR4190 (brazilian clone from Dismac), SR9190 [NW])
Other: 5
Total: 42
P.S. I can trade or sell some of them ;)
Edited: 2 Dec 2003, 3:32 p.m.
Message #9 Posted by GE (France) on 2 Dec 2003, 4:48 p.m.,
in response to message #8 by Nelson M. Sicuro (Brazil)
Hello, Could you tell me what the Sharp EL1611P is ? The "P" in the name puzzles me...
I'm suprised that not too many people have quite a lot of machines. Of course, some people haven't spoken yet like GW (2029 calculators !!!!), JW, VT, DH himself, or the authors of THE GUIDE (about 1500 !!)...
As for me, I have a couple of old 'classic' HPs, and more of the eighties-nineties.
...and I don't tell anything to my wife !
Message #10 Posted by Nelson M. Sicuro (Brazil) on 2 Dec 2003, 6:14 p.m.,
in response to message #9 by GE (France)
The Sharp EL1611P calculator is a LCD adding machine with printer, 12 digits, very common...
http://www.sharp.com.my/web/products/inc_feature.cfm?pcode=EL1611P
Best regards,
Nelson
My favorites
Message #11 Posted by Nelson M. Sicuro (Brazil) on 2 Dec 2003, 6:23 p.m.,
The ones that I like more: HP-15C (my first [1983] but not this one actually), HP-42S (my second, sold my earlier 15C to buy it in 1989), HP-41CV, HP-200LX, HP-32E (RED LED!!!)
The ones that I use in a daily basis: HP-32S, HP-11C
All of them besides the 42S where bought in the last 6 months.... I think I acquired a HP-fever...
Edited: 2 Dec 2003, 6:24 p.m.
Message #12 Posted by Ron Ross on 2 Dec 2003, 1:02 p.m.,
I will just list the ones I do not HAVE:
LCD's 16C 9G 9S 49G+ 17BII+ 48GII 39G+
LED's 34C 31E 29C 19C 27 22 10 55 65 67 80 70
So I am missing a total of 19 of Hp's calculators. Boy am I in sad shape! I will have to buy a couple shortly.
But I will try to consol myself as to not having some of the above. I don't try to collect the business calcs, unless they just fall into my lap. 6 of the above are new Hp's that I haven't even seen retail.
So that leaves me with my must have list down to 16c, 34c, 27, 19c, 29c, 55, 65, 67. That is only 8 that I reeeally miss at the moment.
I also have a large collection of the DARD SIDE, Ti, but they are cheap and easy to come by (no $500 Ti-59, mine were much less). I have nearly every scientific USA released Ti (I didn't say all, as Ti has so many, and I have probably overlooked some model, and again, it would be easier to list what I don't have).
I have Casio's and Sharp's as well, but not deep collections as their difference in pocket calcs isn't as pronounced.
I an assortment of other brands as well.
I haven't yet done an actual inventory for two reasons.
I haven't taken the time.
But even more, I don't really care to let people know HOW ADDICTED I am to this hobby. ie Question, well how many Calcs do you have? Me, "Well, I have a lot." vs haveing to say some ridiculously high number and prove that I am past hope or help.
Nice collection! (+)
Message #13 Posted by Sergei Frolov on 2 Dec 2003, 1:18 p.m.,
in response to message #12 by Ron Ross
How many Russian or own made calculators you have also?
Re: Nice collection! (+)
Message #14 Posted by Ron Ross on 2 Dec 2003, 1:28 p.m.,
in response to message #13 by Sergei Frolov
I have two (maybe a third, buried somewhere).
My favorite is the MK 61 and the other is a Casio LCD pocket type scientific (the model # escapes me). The MK 61 is fairly easy to find, RPN, loaded with functions, but does not have that Hp feel. But it is COOL with a GREEN LED.
Message #15 Posted by Sergei Frolov on 2 Dec 2003, 1:37 p.m.,
in response to message #14 by Ron Ross
Yes, the MK-61 is very beautiful calculator. I think that you have also a MK-51 (IC topology was stolen from Casio fx-2500). A definitely you must have a MK-52 with internal EEPROM.
Message #16 Posted by Ron Ross on 2 Dec 2003, 2:00 p.m.,
in response to message #15 by Sergei Frolov
I am thinking BK-31. It is an older LCD, non-programmable, compact, but very slow, simple calculations make you wait for the screen to update.
And yes, there are quite a few interesting Russian calculators out there.
My list of ones I don't have
Message #17 Posted by Gene on 3 Dec 2003, 10:22 p.m.,
LED: HP-10A, HP-35 red dot, HP-92, HP-97S
LCD: HP-32SII, HP17B, 9S, and 9G (the last 2 really don't count, IMO)
Ones I'm most proud about: HP-70, HP-41C with all bugs
Same as RON with regard to my TI collection.
http://www.rskey.org/gene
Re: My list of ones I don't have
Message #18 Posted by GE on 4 Dec 2003, 5:54 p.m.,
in response to message #17 by Gene
So you have the HP95C, do you ?? (Along with the TI88...)
Message #19 Posted by Gene on 4 Dec 2003, 7:01 p.m.,
in response to message #18 by GE
Lol. I meant of those actually sold.
Now, that doesn't mean I'm not very jealous of Viktor's TI-88.
Gene
Where are all the bugs?
Message #20 Posted by Patrick on 5 Dec 2003, 2:05 a.m.,
Hi Gene
I bought an HP-41C when I was in grad school, over the counter -- not eBay!! -- within a couple of months of their being announced. How would I find out if it had "all the bugs"?
Strange what time accomplishes, eh? After spending that much money on a machine back in 1980, I would have been royally peeved at seeing bugs. Now, folks are proud of them.
Re: Where are all the bugs?
Message #21 Posted by David Smith on 5 Dec 2003, 12:42 p.m.,
in response to message #20 by Patrick
49 STO 00 SF IND 00 (IND is the gold key).
If the BATT indicator comes on then you have bugs. If it says NONEXISTENT you have no bugs.
Message #22 Posted by Gene on 5 Dec 2003, 1:53 p.m.,
in response to message #21 by David Smith
The three early bugs:
Bug 1: After pressing SIGMA+, X was not saved to LASTX (bad)
Bug 2: 49, STO 00, SF IND 00, should turn on the BAT indicator.
Bug 3: 997 ENTER 1234 STO IND Y will store bytes into program memory.
Bug 1 you don't want. Bugs 2 and 3 were on machines with serial numbers of about 1936A or lower?
Message #23 Posted by Thomas Radtke on 2 Dec 2003, 1:21 p.m.,
I'm curious too, are you a collector or do you actually use them?
18C, 20S, 32SII, 48G, Casio fx81p
Actually I use:
Message #24 Posted by Sergei Frolov on 2 Dec 2003, 1:26 p.m.,
in response to message #23 by Thomas Radtke
Actually I use the TI-89, (more often) Casio fx-991MS and also Panasonic 8800.
Edited: 2 Dec 2003, 1:35 p.m.
Too Many and Not Enough
Message #25 Posted by Paul Brogger on 2 Dec 2003, 1:26 p.m.,
. . . depending on time of day and who you talk to. ;^)
HP: 10BII, 19B, 22, 28C, 28S, 32S, 32SII, 34C, 41CV (NW), 42S, 48G, 49G+, 97.
TI: Datamath, SR-11, 30, 55, (LED) and 83+SE (LCD).
SHARP: PC-1201 (VFD), PC-1360 (LCD), EL-5000 (VFD), EL-5100 (LCD), EL-5100S (LCD).
Misc. LED: Craig 4516, Commodore "Minuteman 3", Litronix 2260 "exponential", National Semiconductor 4510 "Mathematician".
Misc. LCD: ~20.
Several slide rules and a Monroe LE-1307 "Educator" mechanical calculator.
FWIW . . .
Re: Favorites
Message #26 Posted by Paul Brogger on 2 Dec 2003, 6:58 p.m.,
in response to message #25 by Paul Brogger
My favorite overall is the HP-97.
For day-to-day use, I was using my HP-32s, and that's my favorite knock-around calculating calculator. (I suppose I'd love the 41, if it worked.)
Lately, I've been spending all of my spare time with my 49G+, and am actually enjoying it a lot more than I would have guessed.
Message #27 Posted by Patrick R on 2 Dec 2003, 1:34 p.m.,
Being a young physicist, it is essential for me to use high quality calculators, now and during the next 20, 30 or even 40 years to come. As the situation concerning new RPN calculators (that work ...) is nothing but a pity, my "stock" is composed like this.
4 48GX ENTER x (1 used daily, 2 new in the box, 1 like new)
6 32sii ENTER x (1 used almost daily, 5 new in the box (4 of them brown ones), 1 like new)
1 42s ENTER x (for playing around sometimes, like new)
1 x 20s (because most of my high school students use it)
and not to forget the 200LX, great for running Derive and playing around with Pascal and for using those otherwise useless 8Mb compactflash cards that came with the digital camera.
Message #28 Posted by Victor Koechli on 2 Dec 2003, 1:55 p.m.,
I have around 25 HPs, 2 TIs (58C and 59), plus a Monroe mechanical adding machine (if only I knew where to find the model number...) and a 13-digit soroban.
Still, I don't collect with respect to the value: I have no boxes and only the models I like (the scientifics, that is, and RPN only, except for the TIs ;-)). None is like new or NIB, especially not the heavily used 15C. And I use them, especially the 48SX which has become my favourite and which I carry around all the time.
PS Is a soroban RPN? I'd say not, but it's not infix either, and certainly not prefix. But what, then?
Re: Monroe Serial #s
Message #29 Posted by Paul Brogger on 2 Dec 2003, 2:40 p.m.,
in response to message #28 by Victor Koechli
I hope my experience will be of help.
I found the model and serial # of my Monroe stamped on a segment of the internal framework, and visible from below through a rectangular slot cut in the case.
Go well,
PB
Message #30 Posted by Victor Koechli on 2 Dec 2003, 4:59 p.m.,
in response to message #29 by Paul Brogger
Thanks, Paul! Yes, indeed, your experience helped: My Monroe has serial # L-147676.
Seems a long time since I played adventure and was used to solving riddles and puzzles...
Do you have any idea what these serial numbers mean? A quick google search revealed a lot about cars and Marilyn, but nothing about these number's meanings. Especially I'd like to know how old the machine is, as this amazing beauty is still working perfectly!
Thanks again, Victor
Message #31 Posted by Paul Brogger on 2 Dec 2003, 6:54 p.m.,
in response to message #30 by Victor Koechli
A helpful person responding to my question posted on CALCLIST-L offered this about my machine's serial # ("LE-1307-271258"):
"Some information that you might find interesting. The LE-1307. The L stands for a whole series of Monroes in the L series. The E does stand for Educator. 13 is for 13 lower dials,and 07 is for number of keyboard rows."
And someone else came up with:
" ... Does your calculator have flip down legs at the rear? There were two different styles of cranks (old style), one for a thin case, and one for a full case. I believe the LE has a full case ... "
and
" ... This machine base is the Monroe L-160-X (old style), or LN-160-X (new style). The internal workings of both machines are nearly identical. The Educator series was a reduced features offering for school sales at reduced cost."
and,
" ... The calculator that you own was used in business colleges, and universities across the US for teaching purposes.
"The portable model of the calculator (L-160-X) was the machine that performed all of the calculations that built the American road system. Nearly every field surveyor employed by the US Bureau of Public Roads, and every state Dept. of Highways used one of these machines. I serviced these machines for several years, and usually dreaded the surveyors' off seasons when these men would bring dozens of the calculators in for servicing.
"The calculators were carried by salesmen and auditors. The portable versions of your calculator cost over $300.00. A lot of money at the time."
[Victor, based on its flip-up legs, I'd guess yours is a portable "new-style" model, maybe an L-series too. But don't take that to the bank -- I'm no expert.]
By the way, both of the folks who offered the information above are experienced Monroe service people, and one of them has spare parts available(!) (I was able to buy a handcrank and a xeroxed instruction manual for a very reasonable rate!)
So, bottom line: hook up with CALCLIST-L and you'll get more information than you may have thought possible.
Message #32 Posted by Trent Moseley on 2 Dec 2003, 2:50 p.m.,
I have the following HPs:
25C used for one astronomy program. 67 astronomy programs on cards. 15C astronomy programs 42S astronomy programs 32Sii not much 12C income tax 16C checkbook
Previous HPs: 11C given to a friend, 31E gave to a son, and a 48GX to a nephew.
Also: Sharp PC-1500A, Sharp made Radio Shack TRS-80, TI-1786 (TI Card), Sharp EL-8061E Elsi Mate, Heathkit IC-2008-A
Pickett Slide Rules: 10" N500-ES and 6" N600ES.
Favorite: HP-15C.
tm
Message #33 Posted by Arnold Steekelenburg on 2 Dec 2003, 2:20 p.m.,
HP25C HP65 HP67 HP41C HP41CV HP41CX HP38G HP39G HP40G HP48G HP48GX HP49G HP49G+
from 1 to 12 in a few months
Message #34 Posted by Emmanuel Verbeeck on 2 Dec 2003, 2:35 p.m.,
Nine Hewlett-Packard : 41CV, 71B, 15C, 28S, 34C, 25, 42S, 67, 49G+;
One Sharp : EL-512;
Two Texas Instruments : 58, 59.
... And I still manage to tell my girlfriend this is reasonable and justified ;-)
Message #35 Posted by Holger S. on 2 Dec 2003, 3:08 p.m.,
HP's: 41CX 42S 71B 28S 11C 95LX 100LX 48GX
Casio 602P 4000P 4500P
Sharp PC-E500
The 48GX and the E500 are for sale on ebay because I don't like them.
Message #36 Posted by Tizedes Csaba on 2 Dec 2003, 3:18 p.m.,
Two TI 57LCD one CASIO FX-850P with RP-8 8K RAM module one HP 32SII original brown-blue-yellow one HP 15C one HP 17BII one HP 28C one HP 48SX two PTA-4000+16 with printer (equal with SHARP PC1500, but it had +16K RAM) one 250mm long plastic Faber-Castell slide rule one 125mm long wood Gamma slide rule one PSION ORGANISER LZ64 with 128K DATAPAK one Commodore 16 one Enterprise 128K
I saled an HP 45, and I traded an HP 10C.
Csaba
Message #37 Posted by Gordon Dyer on 2 Dec 2003, 5:27 p.m.,
Here is my collection...
Make Model
Addimult Sumax-E
Allied Slide Rule
Braun ET 100
Braun ET 66
Budenburg Guage Co. Circ.Slide Rule
Burroughs C3260
Casio CFX-9850G
Casio DC-800GY
Casio fx-450
Casio fx-82 solar
Casio fx-85MS
Casio fx-85WA
Casio CM-604 mini
CBM 774D
CBM 776M
CBM C108
CBM SR7919
CBM SR7919
Chambers Seven-Figure Logarithms 1954
Citizen SLD-715B
Colex 811A
Commodore 796M
Commodore 796M
Commodore F4902
Commodore GL-976M
Commodore GL-997RF
Commodore LC5K3
Commodore LC5K3
Commodore P50
Commodore SR4912
Commodore SR7919
Commodore SR7949
Commodore SR8120
Commodore SR9190R
Compucorp 342
Compucorp 324G
Elektronika MK-52
Elektronika MK-61
Fearns Circ.Slide Rule
Hewlett-Packard HP-6S
Hewlett-Packard HP-10B
Hewlett-Packard HP-10BII
Hewlett-Packard HP-11C
Hewlett-Packard HP-12C
Hewlett-Packard HP-14B 50th
Hewlett-Packard HP-17BII
Hewlett-Packard HP-20S
Hewlett-Packard HP-21S
Hewlett-Packard HP-22S
Hewlett-Packard HP-25
Hewlett-Packard HP-28S
Hewlett-Packard HP-30S
Hewlett-Packard HP-32SII
Hewlett-Packard HP-35 v2
Hewlett-Packard HP-38C
Hewlett-Packard HP-41CV
Hewlett-Packard HP-41CX
Hewlett-Packard HP-42S
Hewlett-Packard HP-48G
Hewlett-Packard HP-71B 1AAAA
Hewlett-Packard HP-71B 1BBBB
Hewlett-Packard HP-97
Hewlett-Packard Jornada 548
Hewlett-Packard HP-82240B
Imperial 90S
Kreiger Formulae Book -recommended By Albert Einstien!
Lotus Flower Abacus
Olympia CD 100
Prinztronic M500
Psion 3c
PYE P-640
Rapid Data Systems Rapidman 800
Rockwell 18R
Santron 20S
Sanyo ICC-802D
Sanyo ICC-1122
Sperry-Remington 661D
Texas Instruments TI-1025
Texas Instruments TI-2500 Datamath
Texas Instruments TI-2500B Datamath
Texas Instruments TI-3500
Unisonic 811
Universal 999
Wiley Trigonometric Tables 1937
WHS Albert2
Message #38 Posted by Patrick on 2 Dec 2003, 10:39 p.m.,
I have 76 HPs (about 2 dozen TI's but not too sure):
 4 x HP-10C
 7 x HP-11C
10 x HP-12C
 8 x HP-15C
 4 x HP-16C
 1 x HP-19Bii
 1 x HP-19C
 2 x HP-20S
 2 x HP-21
 1 x HP-22
 2 x HP-25
 1 x HP-27S
 1 x HP-28C
 2 x HP-28S
 1 x HP-31E
 3 x HP-32Sii
 1 x HP-33C
 1 x HP-34C (thanks Katie)
 1 x HP-35
 1 x HP-38E
 1 x HP-38G
 1 x HP-41C (bought early 1980)
 1 x HP-41CX
 6 x HP-42S
 1 x HP-45
 3 x HP-48G
 2 x HP-48GX
 1 x HP-55
 2 x HP-71B
 2 x HP-80
(I hope that adds up... wait... let me try to find a calculator...)
Message #39 Posted by Katie on 3 Dec 2003, 12:26 a.m.,
in response to message #38 by Patrick
I'm too embarrassed to say ... and this thread is making me feel like my collecting has gotten way out of hand. I better start taking some pictures for ebay sales :)
Re: [VPN] How many calcs do you have. (curious)
Message #40 Posted by Veli-Pekka Nousiainen on 3 Dec 2003, 6:46 a.m.,
in response to message #39 by Katie
Hello, Katie!
Maybe you have something missing and I have something missing. Lets SWAP! Just DROP_NOSPAM.
[VPN]
Message #41 Posted by Veli-Pekka Nousiainen on 3 Dec 2003, 6:45 a.m.,
10*12C?, 8*15C? Wow!
Patrick, can discuss about swapping these extras to something you have zero pieces? just DROP_NOSPAM.
[VPN]
Message #42 Posted by Patrick on 4 Dec 2003, 1:40 a.m.,
in response to message #41 by Veli-Pekka Nousiainen
Extras? Which extras?
Re: [VPN] How many calcs do you miss, Patric?
Message #43 Posted by Veli-Pekka Nousiainen on 4 Dec 2003, 2:29 a.m.,
in response to message #42 by Patrick
Posted by Patrick on 4 Dec 2003, 1:40 a.m., in response to Re: How many calcs do you have. (curious), posted by Veli-Pekka Nousiainen on 3 Dec 2003, 6:45 a.m.
VPN Quote: 10*12C?, 8*15C? Wow! Patrick, can discuss about swapping these extras to something you have zero pieces?
Patrics answer: Extras? Which extras? ;-)
VPN continues: seriously - if you are missing something, will you please write to me, just DROP_NOSPAM.
[VPN]
Message #44 Posted by Ben Salinas on 2 Dec 2003, 11:47 p.m.,
I think I win for having the least calculators and the newest aged collection.
I currently have 3 calculators in my posession: A 32sii (silver bezel) A TI-89 and a 49g+.
The only one that actually belongs to me is the 49g+. (The 32sii and the 89 belong to my school).(And I didnt even buy the 49g+)
Favorite (of the 3): 32sii
Well, I guess you could count those old TI-30's that I haven't touched in over 2 years:)
-Ben Salinas
Two whole years?!
Message #45 Posted by Patrick on 3 Dec 2003, 12:21 a.m.,
in response to message #44 by Ben Salinas
You young'uns... you make it sound like 2 years is a long time... lol...
Message #46 Posted by Michael B on 3 Dec 2003, 2:22 a.m.,
I've never stopped to count them all. Somewhere in the mid-30s or so I guess (I'm not sure if the ubiquitous Ti-80 whatnots should be included). My favorite is probably the Sharp EL-5150, although right now I'm using an HP-11c at home and an HP- 97 at work for everyday calculating. But every now and then, it's fun to switch (the 35, 33c, 34c, 67, 71b, 28c, and 41c have recently had their turns).
Say, does anyone know anything about Kings Point calculators? I've got an SC-20 and SC-40 and they've been a hoot to poke around in (the SC-20 appears to be hand soldered!). I'd love to learn more.
Message #47 Posted by Massimo (Italy) on 3 Dec 2003, 12:47 p.m.,
~170 HP
 ~20 TI
   2 Sharp
   1 Elektronika
   1 Novus
   some crap... and
   1 wife puzzled by this hobby
You can see some of them (never find the time to complete shooting sessions) here http://utenti.lycos.it/max/html/calculators.html
No more missing handhelds, BTW.
Massimo
Message #48 Posted by Larry Corrado, USA (WI) on 3 Dec 2003, 2:18 p.m.,
My Collection:
HP: 26 units. Mainly Woodstocks, Voyagers, and Spice; a few Classics, Pioneers; some modern models.
TI: 160 units. Mainly handhelds, from Datamath to present.
Misc: TRS-80 PC-2 (Sharp PC-1500), some Casio and Sharp
Compet 33: from 1960s(?), nixie tubes
One beautiful Curta II, from my sports car rallying days.
A dozen slide rules, misc other analog (hand) devices.
My favorites: Well. I used Woodstocks for 25 years, but I've just recently becomes familiar with Voyagers. I'll have to pick the HP-15C and 16C.
Regards, Larry
Message #49 Posted by John L Shelton on 3 Dec 2003, 11:52 p.m.,
in response to message #48 by Larry Corrado, USA (WI)
I broke the ugly habit. While I've owned many over the years, I am down to one (HP-15C).
Buying the MoHPC on DVD helped me kick the habit.
=John=
