Oh no! Message #1 Posted by Brandon Del Bel on 2 Dec 2003, 10:09 p.m.
I discovered last night that my 49g+ won't connect to conn4x anymore. Device manager assures me that my "HPx9G+ DEVICE" is "working properly", but conn4x tells me "Error (The connectivity kit is unable to open communications to: HPx9G+)". I'm supposed to run XSERV (right shift + right arrow), correct? Everything worked when I upgraded to 1.22, and I'm pretty sure it worked after that, too. I don't think the problem is with the computer because it doesn't work on either my desktop or laptop (both running win2k-pro sp4). I'm not even sure if it is a problem with my calculator, though, because it passes the USB test. I'm not familiar with the EMI test, though. When I connect the cable for that one, the screen fills with H's. Do I have a problem that I can fix, or do I have to send it in for replacement?
