HP-97 PRINTER Message #1 Posted by Jon on 30 Nov 2003, 1:51 p.m.
I have an HP-97 with the typical broken gear in the printer. Getting a new one of these gears in Europe is quite difficult. In the other hand I have also an 82143A printer (the one that works with the HP-41 calculators). I see the printer itself is very similar. Most of the components are just the same, and it woks with pulleys instead of gears (clearly improved design). Even the assembly points are the same and I am sure it fits perfect in the HP 97. The connectors for the engine and paper detection are identical. The flex connector must be changed but that is easy. However the engine is bigger.
As these printers are not so expensive, I think they could be a very good source of spare parts. Has anybody tried to install the printer of the 82143A in one HP-97 (or HP-91, HP-92)?
