Re: Recommended cells? Message #5 Posted by Randy Sloyer on 27 Nov 2003, 12:07 p.m., in response to message #3 by Juergen
I use Gold Peak 16AAAM - 1.2 Volts, 160 mah. Rated for 16ma charge, 16 hours. Perfect match, they need some filler to take up the remaining volume in the case. 1/16" double sided foam works well to hold them in place.
