Re: HP67 magnetic-cardreader Message #4 Posted by David Smith on 27 Sept 2003, 2:09 p.m., in response to message #3 by Harry
There is another common reader problem that you may have. The worm gear is press fit onto the motor shaft via a nylon bushing. This friction fit may wear loose or the bushing may be crumbled. If this happens the motor will spin, but the gears will not.
