Re: 9114 drives Message #2 Posted by Vassilis Prevelakis on 22 Sept 2003, 1:51 p.m., in response to message #1 by christof
christof wrote:
>I have a few HP-9121 units, [...]
If you are thinking of replacing a drive from the 9121
with that in the 9114, it won't work. The pinouts may or may not be the same (9114A drives have the same pinouts, 9114B
have the newer single connector that carries both data and power), however, the drives are different.
The 9121 have single sided drives, while the 9114 are double sided.
You may be able to use drives from 9122 devices.
Alternatively you may try to use parts from the drives inside the 9121 but that depends on what is wrong with the
drive in the 9114B.
**vp
