Re: 41CX with dead extended memory Message #3 Posted by dbrunell on 20 Sept 2003, 8:25 p.m., in response to message #2 by christof
Thanks for your reply. Yes, CAT 4 gives DIR EMPTY and 124 in the X register. So it's like the machine thinks it's got a full memory there. When I try to save a program with SAVEP, no errors are generated. It must do a write without verify because if I immediately do a CAT 4 I get DIR EMPTY and 124.
When I got the unit, the batteries had been out of it for over a week, so it had time to do a hard, cold reset. I've had the batteries out several times since and did numerous <-/ON clearing operations.
I'm guessing that the extended memory (and clock) are on that little board soldered piggyback to the main board. I haven't pulled it off yet, but it doesn't look like there is much that can be serviced on it, save for maybe a shorted capacitor. I'd further guess that the actual rom functions are on the main board, since it has no trouble finding and executing them. Surprisingly, the clock works just fine.
Dave
