Re: HP49G+ sd-card size Message #2 Posted by Veli-Pekka Nousiainen on 16 Sept 2003, 4:09 p.m., in response to message #1 by Juergen Rodenkirchen (GER)
"reasonable recommendation on the size for sd-cards used with an HP49G+?"
For absolute compatibility & low budget, if you are planning or already use a Nokia Phone with MMC, I recommend a 64MB MMC. On the other hand, if you want to use the card with digi-camera, get the largest SD (512MB), but you're better off with a camera using CF. CF can go 4GB with FAT32. You may consider cheapest SD available. The calc doesn't need that much memory. I currently use an old 8MB MMC and it's ok.
