I forgot to mention... Message #4 Posted by Randy Sloyer on 12 Sept 2003, 8:23 p.m., in response to message #3 by Tom Scott
One thing I failed to mention was not to jam the tube in so far as to split the bottom half from the top. The older windowed version machine bezels will distort a bit, possibly leaving a wrinkle. Uggh. You just need to direct the air blast between the halves and the tapered tip helps alot.
Edited: 12 Sept 2003, 8:24 p.m.
