Re: HP45 self-tests? Message #4 Posted by Bill Wiese on 8 Sept 2003, 8:14 p.m., in response to message #3 by barry
Hi Barry...
I commend you on your trying to be a good-faith seller and caring about what your purchaser buys.
See that entering 8.888888888 [CHS][EEX] 88 [CHS] results in a display of "-8.888888 -88" (oops, might have gotten one too many '8' digits in the mantissa).
See that every key "does something". See that you can store and recall numbers into the memories. See that changing one memory doesn't wipe out another's contents.
On a calc like an HP45 if a few calcs work and the keys work and the display lights OK then you're pretty well off.
If anything failed in the ROM or ACT chip the whole calc would've gone haywire. (Not necessarily true of higher-end later programmable calcs.)
Get another sci calc (even cheapie non-HP is OK). Run them back to back for several calculations on log & trig functions. They won't be exactly the same (HP's prob better!) A good test:
[9][sin][cos][tan][f][arctan][f][arccos][f][arcsin]
should end up with a number close to 9:
9.004076644
is what the Calculator Forensics project at http://www.calcinfo.com says the HP45 produces.
Bill Wiese
San Jose CA
