Re: HP-49G+ keyboard issue Message #2 Posted by dbrunell on 8 Sept 2003, 4:56 p.m., in response to message #1 by Daniel Diggelmann
Daniel, thanks for putting up the great pictures so that the rest of us can see the HP49G+ up close. Making the change you suggest would indeed reduce the force necessary, but it would also increase key travel. How does the 49G+ key travel compare to the 41C? I'm inclined to believe that changing the leverage would not affect the reliability of contact closure. That would be more a factor of the dome design and materials used. The classics had gold plating on the PCB.
