Re: HP97 keyboard Message #2 Posted by Katie on 5 Sept 2003, 11:15 a.m., in response to message #1 by Chan Tran
The 97 keyboard doesn't "click" so I assume that you mean that the key press isn't making good contact. Anyway, it's pretty easy to disassemble the 97 keyboard and clean it.
Once you open the 97 case (6 screws) there are another few screws to remove the keyboard from the top of the case and then a bunch more screws to remove the contact PCB from the keyboard itself. But you don't have to worry about any pieces falling out, all the keys and springs are kept in place by caps on the end of the key stalks. Just clean the gold plated contacts and the gold plated contact matrix with isopropyl alcohol and that should fix your problems.
