Re: HP-25 internal Power Circuit Charger Message #2 Posted by Tony Duell (UK) on 1 Sept 2003, 4:21 p.m., in response to message #1 by Albert
Sure. The chearger circuit is very simple, it consists of 4 components in series. They are :
The AC adapter secondary winding; A diode (try a 1N4007 or similar), a 8.2 Ohm resistor (looks to be at least 1W, maybe 2W), and the NiCd pack. The diode's cathode (banded end) goes towards the +ve terminal of the battery.
That's it. The actual 'reserve power pack' is a bit more complicated as it has an LED to indicate the batteries are on-charge, I can dig out a schematic of that if you like.
