Spice troubles Message #1 Posted by dbrunell on 27 Aug 2003, 10:48 p.m.
I have a 33E which I acquired recently. It looks brand new, but that is about the only thing positive you can say about it. I got past the trauma of opening the case. Alas, it is a solderless beast.
Here is the trouble I am having. On DC power (2.4 V to the battery terminals), I get no display whatsoever. On AC, I get a flickering display of either all zeros or just a lone decimal point on the left side. Keys seem to have no influence. I tried pressing the flex sandwich this way and that with no noted effect. There is no corrosion on the ICs or flex circuit. It really does look brand new inside and out.
Any ideas? Does anyone have a schematic? I'm thinking it is perhaps a simple problem with the power supply.
One other thing...is the silver 8-pin IC only supposed to have 7 leads?
Thanks and best regards,
David
