HP-41C LCD Message #1 Posted by Terry on 10 Aug 2003, 8:12 p.m.
okay, I corrected it to LCD - thanks.
I have an HP-41C that I kept in a closet for several years when I did not need it. When I finally needed it again, I found the LCD has a brown haze to it. But it looks more like something under the display cover (if there is such a thing).
I would like to know if that is true, that there is a separate cover protecting the LCD, and if I can get to it easily for replacement or cleaning. The repair info posted here does not go into removing the LCD, so I do not know if I can and whether or not the risk of having a non-functioning calculator would be worth it. The only thing bothersome about it is that it looks dirty.
Edited: 11 Aug 2003, 7:41 p.m. after one or more responses were posted
