Re: HP95LX HELP !! Message #4 Posted by Bill Smith on 6 Aug 2003, 1:45 p.m., in response to message #1 by Rick VanHuss
don't give up hope on the PCMCIA card. there are files at palmtop.net that supposedly allow use of sandisk cards, and these are very cheap. even SRAM cards come up on ebay occasionally.
i have the manual at home, and will check on serial connection info, since you have to get the driver into the 95lx to use a sandisk. also, there is the IR port. you can use a terminal program with the serial cable if you don't have the connectivity kit software. there is a wealth of info at the links posted by Katie.
guess i was lucky to get the 95lx, manuals, cable w/ connectivity kit, and sram for $45 :)
