Re: HP-41CV - Card Reader Message #2 Posted by Vieira, Luiz C. (Brazil) on 28 July 2003, 7:12 p.m., in response to message #1 by Frank V
Hi, Frank;
what you wrote leads to I/O problems (most likely to be bad contact) in your CV. The best remedy would be to open the calculator and clean the contacts between the BATT/IO assembly and the calculator contact pads. You could also test another extension (printer, wand, ROM module) in port 4, the one used by the reader, and see if they also fail.
If the reader works fine in the HP41C, the HP41CV I/O is the first to be checked.
Success. And let us know if you need more advice.
Luiz (Brazil)
Edited: 28 July 2003, 7:22 p.m.
