Re: HP48GX screen replacement Message #4 Posted by Ron Ross on 14 July 2003, 10:12 a.m., in response to message #3 by Ohneil
You could try to fix by yourself, if you are skilled with repairs. You only need the LCD screen from an Hp38G or another 48G (you can buy for about $25-40 for either, the 38G can be purchased new for that). However, you will probalby destroy the first calculator you open, so you should wait until you recieve your replacement calc before you operate.
There is no guarantee of your success either. However, Hp themselves used to offer a replacement policy for out of warrenty calculators of around that cost also. Then you would get a new unit (or just like new as it may be a refurb ie returned for some reason or another).
Ph # 970-392-1001 ext. 0
I haven't dealt with for a couple of years (I had a bad 49G, first issue).
