Re: SOLVED !!!!! Message #7 Posted by Vieira, Luiz C. (Brazil) on 21 June 2003, 11:47 a.m., in response to message #6 by Jon
Hi;
I posted a photo a few days days ago showing an opened (dismanteled) halfnut and these components are present in at least eight halfnuts I have already opened (two CX and six CV). You may also notice that earlier halfnuts have a post-production cut in the cooper trail where the red wire is soldered, while the newer units have this trail already separated in the PCB layout.
I've been served by a provider that does not care a damm dot for its customers, so the page I was using was removed and created again and all my pictures are gone. I'm lucky I have all of them, so I'll have to upload them all back.
If you want, I can e-mail you the image so you can check if yours is the same type.
Best regards.
Luiz C. Vieria - Brazil
