Funky Spice Display Message #1 Posted by DougT on 17 June 2003, 8:51 p.m.
Hi folks,
The display of my 38E is acting up. At every digit location, the upper left LED segment does not work. Since it's at every digit, I doubt it's simultaneously burned out LEDs. Perhaps something's amiss with the display driver? This is an older unit that may have the "press-fit" chips. I thought I'd see if the resident experts had run into this condition before, prior to cracking it open (with the dental floss trick). I've done plenty of transplant surgery on my Woodstocks, but this will be my first time digging into a Spice model.
Thanks!
Doug
