HP41 barcode: Another issue Message #2 Posted by Vieira, Luiz C. (Brazil) on 13 June 2003, 9:46 a.m., in response to message #1 by Meindert Kuipers
Hello, Meindert;
your idea brought another one to my head: why not using commercialy available barcode readers and then create a custom HP41 decoder (or coder)? Aligning the original image, scanning it, reducing image errors and the like would also be fast and SW demanding; I think current PC-based wands and related drivers/software may generate a stream file with a sequence of bytes from the HP41 barcodes. A single program would break the line into bytes and combine them to form an HP41 valid sequence.
What do you think? You'll need more time to read the barcodes (to wand them) but obtaining final listing without much errors is easier. I used to scan program hardcopies and unse an OCR to retrieve ASCII data. In some cases, when original hardcopy had enough contrast and darker printing, a few instructions needed to be corrected. In some cases, with old paper with few contrast and failing characters, keyining in the program was easier. After that, 41UC could generate any equivalent, even .PS barcodes.
Hope this adds a bit to yout original and very good idea.
Best regards.
Luiz C. Vieira - Brazil
