Re: 9815/9825 tape drive Message #2 Posted by Tony Duell (UK) on 12 June 2003, 6:24 p.m., in response to message #1 by Achim
That bulb runs straight off the 5V line, and is not that bright, so it's probably a 6V bulb. I think there's a 6V, 60mA bulb about that size, which I'd try first.
There are 2 bulbs in the tape drive, one to detect the hole in the tape and one for the tachometer sensor. They are in parallel electrically, and AFAIK the 2 bulbs are the same type, so if only one has failed you could measure the current through the good one to get some idea of the rating.
