Re: Have you seen this?? Message #7 Posted by James M. Prange on 2 June 2003, 1:12 a.m., in response to message #5 by james (UK)
Or maybe a 48 descendent, with a USB port in addition to the serial port. Some of the newer PCs lack a serial port, so you need an adapter to use them with the 48, and with the amount of memory available in the newer calculators, archiving/restoring by I/O can take a lot of time.
But I wouldn't want to do without the serial port either.
Some features could be borrowed from a sibling, the 49G.
