HP-28S Autopsy Photographs Message #1 Posted by Paul Brogger on 9 May 2003, 2:38 p.m.
Folks:
I've taken some amateur close-ups of a broken HP-28s, and thought some of you might like to see them.
1: The back case halves, with everything but the keyboard flex circuit removed.
2: The front case halves, with the PCB.
3: The closer view of the alpha keyboard's inside front.
4: The a pile of keys. (This should give you some idea of how the double-shot molded keys look and how the keys are hinged on the Clamshell models.)
5: The PCB front, with many LCD connection pads, above & below.
6: The PCB back, with RAM chip and keyboard connection pads.
7: A "personality shot" of the PCB, backlit by a slave flash unit. The idea is to emphasize the CPU chips suspended in space by a rectangular array of micro-fine wire connections.
These are all a first cut with various pieces of equipment gathered from the thrift store. I'll probably try again with better lighting, smoother background, etc.
The pictures look ENORMOUS when I link to them. If someone has a suggestion on how to reduce their initial presentation, I'll give it a try.
The HP-28s itself had been "flexed to death" in my son's over-full backpack. You'll notice that nearly ALL of the pins meant to connect the front and back case halves have broken. I may rebuild it using a drill press and a lot of tiny screws and acorn nuts. (It would be kind of neat to have an industrial-strength HP-28!) Meanwhile, it's a good subject for autopsy.
Enjoy!
