Re: HP41C Battery Message #2 Posted by Randy Sloyer on 8 May 2003, 12:03 a.m., in response to message #1 by Jack Ferman
Standard N's are alkaline.
The 82120A rechargeable pack had 1/2 N ni-cad cells which are no longer available. You can replace the ni-cads with 1/3 AAA Nickel Metal Hydride cells. They have more than 2X the capacity of the ni-cads. The Battery Station sells pre-fabed 4 cell replacement packs with the proper length tabs for less than $20. Just tell them it's for an HP41 and they know what to do.
You'll need to add some filler to keep the cells from rattling around as they are smaller. I use 1/2" x 1/16" double sided foam tape, works very well.
