Re: HP49G IF-structure bug? No success ... Message #6 Posted by Juergen Rodenkirchen (GER) on 11 Apr 2003, 8:26 a.m., in response to message #5 by Vieira, Luiz C. (Brazil)
Hi Luiz!
>What is the sequence you use to call the PRGM menu to the top key roll? If I use 23 MENU [ENTER] and press [left-shift][IF] or [right-shift][IF} I get one of both IF-THEN-(ELSE)-END structures.
I'm using here [left-shift] PRG BRCH IF to get there (I'll try 23 MENU [ENTER] tonight). Then I encounter either of the following phenomenons:
1. [left-shift] [IF] returns IF THEN END ok. But subsequently pressing [left-shift] [IF] (e.g. in order to insert an IF THEN END after the 1st IF) stalls the machine.
2. [right-shift] [IF] returns IF THEN ELSE END but stalls the machine immediately.
> Aren't you willing to upgrade just for checking pourposes? If not, don't you consider reloadind current installed O.S.? If it is data corruption, reloading may solve the problem. I'd also try another copy.
It has just been curiosity if there's some sort of bug in OS 1.18 ...
> BTW, did you observe this behavior before? I mean, have any idea of any particular alteration/addition/removal before the symptoms being observed? It might help further analysis.
Well, I've just started to use this HP49G which I bought 2nd hand. So, I can't tell what the previous owner did with it (except of loading 2 libs that I purged lately). Anyway, I'm currently enjoying the excellent Trigonometry-, ComplexNumbers- and SequencesSeriesLimits-Marathons of Nick (can't remind his complicated, long greek name)-- b.t.w., an absolutely incredible work that the guy did here. I have had some problems to follow the course due to missing commands with OS 1.18 and so I'm indeed planning to upgrade to 1.19-5 soon anyway. However, thank you very much for your help!
Best Wishes and a have Nice Weekend :-) Juergen
