Re: NOT WORKING HP-41C Message #2 Posted by Vieira, Luiz C. (Brazil) on 23 Mar 2003, 6:45 p.m., in response to message #1 by Jon
Hello, Jon;
based on a few experience dealling with HP41 (I have four working models with me) I'd tell you first: don't panic!
Now let's see. Chances are you have a simple problem of bad connection (bad contact) between the BAT/IO assy (batteries and the I/O port connections and assembled in one single piece) and the keyboard. This is normally due to oxidation from battery leakage.
You can check it by removing the batteries again and looking carefully at the batteries contacts. Can you see any green power that would smear in your fingers? This is the sort of oxidation that may form under the batteries' contacts. Sometimes you can see it, sometimes its hidden under the black plastic in the bottom of the batteries compartment that surrounds the BAT/IO assy contacts.
Do you have the skills to open it and try to clean it? It seems to me yours is a fullnut. Please, check for it based on the image below.
Let us know if you are willing to open it or not.
Success.
Luiz C. Vieira - Brazil
