Re: 71b Finally Message #5 Posted by Raymond Del Tondo (Germany) on 28 Feb 2003, 4:13 a.m., in response to message #4 by Joe Edwards
The hand of fate doesn't seem to be good to you...
You sent the money three times, and cancelled the deal three times?
Seriously, You'd make sure the money *is* available
at the time you need to pay the HP-71.
Maybe you could kindly ask the seller to accept the money in two parts, and after having received the second part,
he'd send you the calc.
This could work if you explain the situation to him.
In any case you should give him a guarantee for not cancelling again!
But again: Check your budget before buying;-)
Never buy an expensive toy when you're low on bucks.
Good luck!
Raymond
