HP-67 (soft) display trouble Message #1 Posted by Daniel Conde on 27 Feb 2003, 3:09 p.m.
Hi, my HP-67 display shows a "light shadow" or thin light between the decimal point/dot and the lower display segment. I mean, always, in the decimal point digit, the lower segment is a little bit alight. With the following numbers: 2-3-5-6-8-9 & 0, the decimal point is alight. This fact occurs in every digit (mantissa and exponent).
The problem is not so serious, but I would like to know if can I fix this trouble easily, and how. Thanks!
