Re: Problem with 82143A (HP 41) printer Message #3 Posted by David Smith on 9 Feb 2003, 10:32 p.m., in response to message #1 by Gunnar
Yes, your best bet is finding another printer on Ebay. Changing the printhead out is a rather delicate and involved process. Main things to worry about are flying tiny "C" clips (we don't call 'em Jesus clips for nothing), tearing the flex circuit where it plugs into the circuit board, and cracking the printhead when you tighten down the screws.
Things to watch out for when buying these printers are bad dots in the printhead, missing paper tear bars, stretched out drive belts (a workingable replacement is available from Projector-Recorder Belt Company - www.russellind.com - part SCX2.4), bad paper feed cams, or just a lot of dirt and paper dust gumming up the works. Figure 1 in 3 machines will be unusabale, 1 in three will require work, 1 in three will be fine.
