Re: 42s REGS Variable Missing Message #2 Posted by Gene on 5 Feb 2003, 5:54 p.m., in response to message #1 by Kris Collins
The "REGS" variable can be cleared/deleted by the CLV function.
You can do a SIZE and create it again.
You can also get a default sized REGS variable by doing a master clear, but that's slightly more drastic. :-)
Try the SIZE command and see if that works.
