Re: Working Lifetime of LCD Displays Message #4 Posted by Tom (UK) on 30 Jan 2003, 12:45 p.m., in response to message #1 by Nick Nicholas
I think LCD's are more prone to physical damage, e.g. temperature, shock, delamination etc. So if you look after them well they should last a long time.
LED displays seem more prone to electrical faults in the driving circuitry, I'd guess this is due to the much higher current being drawn. I don't know what the fail mechanism is for LED drivers, I'd guess burnout of the driving circuit or electromigration (over a very long time the internal wiring of the ic gets thin and eventually 'snaps' due to the high current density).
If you own an HP calc it doesn't matter what the fail mechanism is, it still stops working (both are repairable - replace the LED driver or replace the screen).
From this forum there seems (to me) to be more postings about LED problems than LCD - this would imply that 'well looked after' LCD calcs are more reliable than LED calcs but may also be due to LED calcs being older, or users just acepting that LCD's fail so are not too bothered about asking for help.
my 2 pennies worth
