Re: Early HP-42S calcs could also run at 2X under program control! Message #7 Posted by Gene on 11 Jan 2003, 4:47 p.m., in response to message #6 by Erich Neubacher (Germany)
You can also set the HP-42S to run as slow as possible too. You wouldn't notice it when doing calculations, but it would really really lengthen the battery life. :-)
Later model HP-42S calculators can do this speed up MANUALLY by entering the debugger and changing the value as indicated, but they must do it every time the calculator is turned on.
The good thing about the early HP-42S is that it can use this program. I made sure that I used the program by putting "SF 11 ; OFF" as the first 2 lines. Then when I turn the 42S off, the first thing it does when I turn it back on is finish running the fast program.
Always at 2X.
Really makes some of the longer HP-41 style programs, such as Othello, really nice to use.
Enjoy.
Gene
