Re: HP41C does not turn on Message #3 Posted by Vieira, Luiz C. (Brazil) on 7 Jan 2003, 10:12 p.m., in response to message #1 by Jonathan Lenton
Hi;
just for checking purposes: can you check if there is any sort of metal available in the batteries connectors? I once had an HP41 in hands with so much oxidation that the metal suface became dust. I had to rebuilt it, and it is time consuming and somewhat risky. Please, verify it when you scraped the oxidation you did not remove the remaining metal contact. It is a golden plated, cooper sheet over a flexible plastic (what makes a flex PCB). Just check it.
Also, removing the modules when the calculator does not turn to ON is harmless. I recommend doing it with the batteries' holder removed, for safety, when the calculator does not lit.
Do you have the skills to open it? If so, let us know. It is not hard to do, just "taking care" is necessary.
Hope you have succcess.
Cheers.
