Re: HP-41 Synthetic Programming Question Message #5 Posted by Ernie Malaga on 2 Jan 2003, 12:57 a.m., in response to message #1 by Jeff Davis
>Is there a way to obtain the following by using the Byte Grabber? X<=M
Jeff:
Synthetic programming does wonders, alas, not miracles. Specifically, it cannot create a brand-new instruction (such as X<=M). SP has come up with a few new instructions (such as eG0BEEP and W') but those are exceptions.
Unfortunately, there's no way to code an X<=M (at least to my knowledge).
By the way, if both X and M contain numeric data, you can use the X<=Y test; if they contain alpha data, you *must* use X<=NN (available on the HP-41CX).
x<>y
-Ernie
