HP Forum Archive 09
Batteries for HP 15C calculator
Message #1 Posted by Bent on 18 Dec 2002, 5:58 a.m.
I have a HP 15C calculator. But without the 3 micro batteries. Can anybody help with the type ??
Re: Batteries for HP 15C calculator
Message #2 Posted by JasonG on 18 Dec 2002, 7:27 a.m.,
in response to message #1 by Bent
Hi there,
what you need is a set of SR44, silver oxide, cells. They are available all over the place but, unfortunately, come with a wide range of type numbers...have a look at http://www.hpmuseum.org/collect.htm#dispbatt for a bit more information about equivalent types.
The lithium types listed will also work but will not last as long as the silver oxide types.
Regards, and happy hunting...
JasonG
Message #3 Posted by Barry Schwartz on 18 Dec 2002, 3:38 p.m.,
According to the HP15C Manual, the following batteries are recommended:
Alkaline: Eveready A76 UCAR A76 RAY-O-VAC RW82 National or Panasonic LR44 Varta 4276
Silver-Oxide: Eveready 357 UCAR 357 RAY-O-VAC RS76 or RW42 Duracell MS76 or 10L14 Varta 541
Message #4 Posted by Randy on 18 Dec 2002, 10:05 p.m.,
I usually look for everedy 357, then get something compatable to it at radio shack.
Randy
Radio Shack Batteries for Voyager & Pioneer
Message #5 Posted by Karl Schneider on 19 Dec 2002, 4:28 a.m.,
in response to message #4 by Randy
Just yesterday, I bought three German-made, sealed silver oxide #76 cells at Radio Shack for a Voyager calc. P/N is 23-009; price was $2.99 each. They didn't seem to have the cheaper alkaline type.
Re: Radio Shack Batteries for Voyager & Pioneer
Message #6 Posted by David Smith on 19 Dec 2002, 1:34 p.m.,
in response to message #5 by Karl Schneider
Yikes! If you can find them the Vinnic brand of batteries is very inexpensive and actually work rather well. A card of 10 cells sells for $2.50-$3.00. They show up on Ebay quite regularly.
Message #7 Posted by OJM on 20 Dec 2002, 8:02 a.m.,
in response to message #6 by David Smith
I have also used the Vinnic batteries, and they have worked well for me - a good value at that price. If you can't find them, you can still save a few bucks at Radio Shack by finding and purchasing a 6 volt camera/photo battery they carry by the Radio Shack catalog number 23-469. It's a Duracell alkaline photo battery, and it's listed as being equivalent to a PX28AB, A544, and 4LR44 types. The "4LR44" gives a clue about it's insides, because if you then pry off its outer shell, you'll find that it's just a stack of four LR44 cells, three of which will work just fine in the Voyager calc. At $3.79, that's less than a buck a cell, a lot cheaper than buying the cells individually at Radio Shack. Just make sure to buy the alkaline version of this battery, as there is also a lithium equivalent out there that won't work.
Message #8 Posted by Math Geek on 20 Dec 2002, 10:30 p.m.,
Indeed, there is no need to overspend. But even at 2.99 per, that's still only about $0.60/year of go-juice.
