Re: HP 41 C connect to a PC Message #5 Posted by Christoph Klug on 6 Dec 2002, 4:50 a.m., in response to message #4 by Mike (Stgt)
Best solution for HP-41/PC Interfacing is working with HP-IL ! The needed IL-Module is easy available on ebay for low prices, and by using HP-IL your HP-41 works as powerfully system controller - you will get much new applications.
Furthermore you need an IL-RS232 interface box plus the Linux software from Tony Duell - or the HP-IL/Interface Card plus belonging software (the last solution is available from me).
Some surprising news about HP-41 /PC interfacing would be published in the now comming HPCC Datafile Journal and later in HP-Museum...
Best wishes from Germany - Christoph
