Re: HP 11C Stuck key ? Message #5 Posted by Renato on 4 Dec 2002, 7:08 p.m., in response to message #1 by Marty
Maybe it is a stuck key. IF user mode is on AND a label key is stuck this WILL happen, IF there is not a label corresponding to the stuck label key. You can try clearing memory with ON - (Turn off, hold minus key, turn on, release minus key), then run a keyboard test (turn off, hold divide key, turn on, release divide key, press each key starting from top left). Anyway, if the key is stuck, this will not correct the problem, but at least you will know what the problem is.
